Front fork pipe length
Discuss all things 1970 & later Airheads right here
Postby Laughing Gnome » Fri Jun 22, 2012 11:05 pm
as I was changing my front fork oil I noticed the right hand side fork pipe length was shorter than the left. I measured the 2 and found a 1/4" difference. The right side was 8.5" to the bottom of the nut and the left side was 8.75" to the bottom of the nut. What would the cause of this be without removing the springs to check?
right side:
left side:
Laughing Gnome
Re: Front fork pipe length
Postby Major Softie » Sun Jun 24, 2012 12:26 am
Franken Forks?
Postby ME 109 » Sun Jun 24, 2012 12:40 am
Missing spacer? Worn out rubber part?
Find a diagram to get an idea of what's in there.
Postby Tim Shepherd » Sun Jun 24, 2012 12:49 am
I suspect the big rubber doughnut at the bottom of the fork tube on the lower side has met it's demise. It would help to know the year and model too...
Tim Shepherd
Postby robert » Sun Jun 24, 2012 12:54 am
Tim Shepherd wrote:I suspect the big rubber doughnut at the bottom of the fork tube on the lower side has met it's demise. It would help to know the year and model too...
I suspect you are correct.
robert
Postby Laughing Gnome » Sun Jun 24, 2012 8:37 am
yep as some of you suspected, the bushing was completely deteriorated. Thanks for your help.
Laughing Gnome
Return to Post 1970 Airheads
Who is online
Users browsing this forum: p1800cpe and 4 guests
