Upside-down oil control ring
Discuss all things 1970 & later Airheads right here
Postby lrz » Sun Jun 10, 2012 9:49 am
Recently investigated a consistently fouled left cylinder plug to find that I had installed the oil ring backwards.
3k mi ago...
I reversed it ( Duane your website photos confirmed orientation,thank you) but constant rain has limited my riding of late to less than 100 mi. There was less fouling & oil on cylinder walls after the procedure.
But, after searching the web to no avail, is that ring now toast having been run for so long? Or does it need to seat in positioned properly?
:oops:
lrz
Re: Upside-down oil control ring
Postby Duane Ausherman » Sun Jun 10, 2012 10:07 pm
I bet it seats in just fine, but must admit that I have no experience with putting rings in upside down. However, I am pleased to be inexperienced.
I do have experience in many other similar things, just not that one.
Postby Major Softie » Mon Jun 11, 2012 1:41 am
Don't worry, Duane: just turn those shoes right-side up and you'll be fine.
Postby lrz » Sat Jun 16, 2012 10:27 pm
OK, so then where the frig is my oil going?!!
No leaks, bores honed, both plugs now a nice tan/grey, valves seem in order, no smoke at start up (even from sidestand), reed valve new in feb or mar-also made sure small drainback hole was clear & reed oriented properly , running like a top but, as I said, using oil to the tune of 1/2+ qt in a few hundred miles.
Open to suggestions, mates.*
*just for the hell of it
lrz
Postby Duane Ausherman » Sun Jun 17, 2012 1:50 am
After you have 1000 miles on it, test it for oil burning. This is done at night.
Postby lrz » Sun Jun 17, 2012 7:42 am
Doesn't that much oil use seem excessive, though?
BTW, Duane I've sent you an email; comments appreciated...
lrz
Postby Duane Ausherman » Sun Jun 17, 2012 12:20 pm
Irz, email? What was it about?
Postby Motorhead » Sun Jun 17, 2012 1:58 pm
Ahhhhhhhh If your talking about a 2qt change and you find in say 500 miles it lowers on the stick 1/2 but stays there
is normal
the effect is caused with airspace needs in the motor, all 750 to 1000cc motors do it
one could put a bigger 3 qt pan on it you lose a little ground clearance but you will still lose .5 qt
Motorhead
Postby lrz » Sun Jun 17, 2012 4:22 pm
Unfortunately no, Motorhead.
lrz
Postby Duane Ausherman » Sun Jun 17, 2012 7:10 pm
Sorry, not all of these engines lose the first 1/2 qt and then stay there. Some lose almost nothing and stay there. However, it is common for these engines to lose the 1/2 qt and stay there.
I just don't want someone to think that their engines "should" lose the first 1/2 qt and that they have something wrong if the level stays up.
Return to Post 1970 Airheads
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
