/5 cable controls...... easy lever? easy clutch
Discuss all things 1970 & later Airheads right here
Postby Motorhead » Mon Jun 11, 2012 2:00 pm
Recent stroke ( going on 1 year since the event, with slowing developments and weakness on going and currently development) :?
Since I just finished the last construct on my 1 and only BMW ( I decided I need to keep) the work was to help therepy as the exercise was to help me keep and improve :roll:
has me looking into easy clutch and maybe a similer idea for the front brake :geek:
to keep it personal I'd like a home built idea ;)
thanks for any input :D
Lyman
Motorhead
Re: /5 cable controls...... easy lever? easy clutch
Postby Major Softie » Mon Jun 11, 2012 5:03 pm
Motorhead wrote:Recent stroke ( going on 1 year since the event, with slowing developments and weakness on going and currently development) :?
has me looking into easy clutch and maybe a similar idea for the front brake :geek:
Lyman
Someone once posted a link to a home-made easy clutch design that used a roller from a sliding glass door. You could also fab one up using chain like the original "Easy-Clutch" and using a derailleur pulley from a bicycle.
For the front, the easiest thing I can imagine is longer arms for the brake hub - so as to give you more leverage. Obviously, modifying the stock arms would be the easiest option, or you could custom fabricated longer arms. Coming up with a longer brake lever at the bars could also help. Both ideas would, like the easy-clutch, trade more lever travel for easier movement, so it will require careful work to avoid ending up with a brake lever that can be pulled all the way to the bars without achieving maximum braking.
Still, you might do better just investigating modern shoe linings to improve front braking. Also, make absolutely sure that your brake is in perfect condition: clean, lubed, and arms at perfect angle. The front brake gets a lot harder to use when it's not properly maintained.
Postby robert » Mon Jun 11, 2012 5:31 pm
I made longer brake arms for a /5 front brake several years ago. I remember 19 or 20mm longer arms worked well and had a good feel. I would try even longer for more power. I am using a 8" conical brake from a '71-'72 BSA on a bike that uses the same type of cable/lever setup and I doubled the lever length from 1.5 to 3", also works well.
robert
Postby melville » Mon Jun 11, 2012 8:28 pm
No mechanical help here, but I was unaware of your stroke. Hoping you are healing well, Lyman/Motorhead!
Just got the clutch hooked up on mine for the first time in nearly three years, and Whoo--EE that is quite a pull!
Postby Motorhead » Mon Jun 11, 2012 9:51 pm
1st I do have newer material shoes
2nd the front brake system is newly installed, adjusted and working correctly my son had no trouble with it while rideing it
3rd its that I'm losing grip my BMW clutch has been nice as they come its routed the same newer cable, lot of people say its real nice....
the Doc said I would recover 80 to 90 percent in 2 years BUT at almost 1 now I don't seem to have hit bottom
My speech is effected and improved, right hand is what they call clumsy hand and I cannot flaten my hand like a salute the pointer will not strighten out........... makeing the bike SWB and wireing has been a heck of a job, many thereapy excercise seemed the same thing, so I did the refit but as I came closer to finish my left has systoms now and weaker
Keep the ideas comming
Thanks
Lyman
Motorhead
Postby ME 109 » Tue Jun 12, 2012 4:51 am
Lyman, I do hope you fully recover so as to be able to continue with your passion. Building motorcycles.
Postby Motorhead » Wed Jun 13, 2012 10:20 am
I also ride what I build part of the problem with BMW is the high cost of parts, and those that sell used when I could do no better than them I quit selling
and I try to do better thinking when I need something, if you decide how you want it then it shouldn't be too bad
Keeping a bike in a area of spec is certanly the best idea that why I like the /5 simple............
Motorhead
Postby Motorhead » Sat Jun 16, 2012 10:05 am
went to Home Depot and got a mini Hoist Block pully with a 1 1/4 wheel in stainless steel
And I have a simple one piece bracket in mind
Could use a exrta Clam air filter screw to make the next part and I have cable ends from Disc days to finish the hardwear list
Let the juices flow
Motorhead
Postby ME 109 » Sat Jun 16, 2012 10:14 am
Motorhead wrote:Let the juices flow
BBQ tonight?
Postby Motorhead » Sat Jun 16, 2012 10:43 am
Sure Why Not
Beef and Brew are the ticket here
Motorhead
Return to Post 1970 Airheads
Who is online
Users browsing this forum: godot and 2 guests
