Axel nut
Axel nut
1984 R100
At one point I shimmed the wheel to the left to make space for a larger tire.
Now I am changing back to standard (400.- 18) tires. When I shimmed the wheel many years ago, I noticed that there were less threads visible exiting the axle nut. So I safety wired the nut. Would this weaken the nut enough that I should change it to a new nut? Is the nut compromised?
Thanx!
Screen Shot 2022-06-15 at 12.34.03 AM.png (810.26 KiB) Viewed 415 times
Re: Axel nut
I doubt very much that your hole will have compromised the nut to any significant degree... however... if you're in any doubt, a new nut is not going to break the bank...
Re: Axel nut
Zombie Master wrote: Wed Jun 15, 2022 3:34 am Is the nut compromised?
Worse case scenario, it's now slightly cosmetically compromised. :roll:
