Weird buzz in '81 R100 on start.
I've been fiddling with the carbs, starting the motor alot.
I've had the starter rebuilt as a note. Also a new ICU under the tank.
I noticed a few times (and this is a new one) that when I push the start button I hear a buzzing sound under the tank, like a relay or something, just before it wants to actual turn the starter motor. This is intermittent.
What's that? Is it a starter relay going south?
Generator light on dimly.
This is minor but the gen light never seems to go completely off even at highway speeds. I've cleaned all the contacts, battery is charging.
Haven't figured this one out at all.
As a note, the voltmeter goes whack and pins of and on on the + side, I have a fresh one coming this week, we'll see how that pans out...
Neutral light inconsistent.
Half the time I have to pull in the clutch to start as the neutral light does come on., sometimes it does. Totally intermittent.
I cleaned the clutch switch at the lever, it works fine. Cleaned contacts at both ends of the neutral switch wire.
Do these switches act up or just die?
Rebuilt carbs won't adjust.
Soaked the carbs in Pinesol for 48 hours (disassembled).
Blew out all the passages with compressed air and reassembled with al new o-rings and float needles (shot).
The right side is still sputtering and backfiring at idle.
Anything below 2500 RPM and it surges and sputters.
WFO it seems to run good but of course, backfires when you shut the throttle.
I even ran it around the local loop with the synch port rubbers of by mistake, didn't seem to make much diff in the way it ran. Weird.
While synching I see that the right side idle screw doesn't seem to have any effect on the Twinmax readout when adjusting it. Checked cables for free play etc, cables are new. Diaphrams are good.
Worn out idle screw? I'm going to order up a new one for both sides Monday.
Any insight from those in the know is appreciado...
