Rob Frankham wrote:I'd be worried about the failure to drop beck to zero... that amcks of a physical problem with the needle rather than an electrical problem. I think I'd pull the instrument out of the casing and see if the needle has sticky bearings or any obstruction.
Well, Rob your the man"
After getting a few prices today for 2nd hand tacho $90 - $125 I went back over a few of these posts to see what I have missed, so I took your advice and pulled it apart again cause after the ride yesterday it did not return to zero, it was stuck at 2000rpm.
With it apart and in my hand, yes it was a little sticky, but it looked so fiddely to pull further apart and I didn't really want to take it any further so I turned on the compressor and reach for the "carbie cleaner" and took notice on the back of the can that said to keep away from "electric boards", WTF I thought, just a little won't hurt so I aimed it up nicely and gave it a little squirt and then hit it with some low pressure air.......BINGO
I'll see what happens....
