Engine rear mian seal..."new" style vs "old" style
moosehead
Post by moosehead »
The bike 1978 R100/7 -- "under the plywood behind the drive shed" find
Been sorting out ths bike last few weeks. Surprisingly in pretty good shape both mechnically and cosmetically...considering
Checking clutch etc and loads of engine oil in case pointed me to rear main seal and/or oil pump O ring. So off with the flywheel and ..bingo...both were shot.
Had order into Motobins for few other parts so was adding new main seal and O ring etc to order. However they list a "new, improved, BMW recommended " replacement seal (teflon?) as well as the old style with garter spring.
Question...guess I'll go with "new improved" one. Is installation of these newer type seals pretty straight forward as older ones? Any special "tricks" Think I read they should go in dry?
I can't find my old main seal installer tool I last used about 10 years ago...think after 2 house moves in last 5 years it found itself in the trash somewhere as I can't find the bugger anywhere. It was a beauty my old neighbour made for me. O well, have to dig through the hockey puck bag as I think they would work with a little alteration....maybe :roll:
dougie
Re: Engine rear mian seal..."new" style vs "old" style
Post by dougie »
http://www.motobins.co.uk/motobins-hints-and-tips.php
Look for "rear crankshaft seals"
I used the "new" style, soaked it in oil for 1 hour, it doesn't leak so far.
moosehead
Post by moosehead »
Yea, Motobins is where I;m ordering the new style seal from.
Soaked in oil for hour? Thought I read somewhere they go in dry but I could be mistaken, Seem to me to oil it up first makes sense to me.
Did you use a seal installer?? I lost, mispalced an old one a friend made for me so was wondering how you put these new ones in? With new ones I was thinking to just tap it in to correct depth but an automotive gearhead friend said the new teflon ones are hard to put in without a proper seal installing tool.
PS: Dougie where are you located? Ontario or out west? Just wonderin', maybe meet up for a ride sometime...if we actually get any kind of decent weather here on Canukstan...ha ha...
Bob
moosehead
Post by moosehead »
Stupid me, I see your located in Burlington in your listing! I pop down to Belfountain to meet a few friends the odd time. If yo go up there let me know...lotsa airheads there last time I was there!
dougie
Post by dougie »
Yes I used a homemade seal installer. I will dig out the picture and specs and post it later today.
moosehead
Post by moosehead »
That would be great...thanks!
Back to THE WEDDING
moosehead wrote:That would be great...thanks!
Back to THE WEDDING
15 yo old oilhead bike escorts! Nice touch.
dougie
Post by dougie »
Well I tried to get this drawing into the computer without any success. Unfortunately I have very limited patience with computers when they don't do what I want.
Someone on here originally sent it to me so hopefully they will show up with the drawing.
mattcfish
Post by mattcfish »
dougie wrote:http://www.motobins.co.uk/motobins-hints-and-tips.php
The instructions used to say to soak them in hot oil. If I recall, when the first Teflon seals came out they were very stiff and even seemed brittle, so soaking made since. The newer ones are much more pliable. I've been putting them on dry with no issues.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
Post by Garnet »
I installed the new style dry about 6000 miles back in one of my /5 engines and the old style on my other about 2000 miles back. Neither leak so I can't tell which is better. :?
