x
Re: Sometimes I get Lucky!
$888! You very rucky man!
I hope it's all a goer
Hey, I seem to remember you gettin' lucky not so long ago.
x
Last edited by Deleted User 62 on Fri Jun 10, 2011 11:21 am, edited 1 time in total.
All of the simple tests show that it is good to go. Me, I would run it just to see what it sounds like.
Yep!Tim Shepherd wrote:It's been awhile since I scored any R75/5, is that what you mean?
x
Last edited by Deleted User 62 on Fri Jun 10, 2011 11:20 am, edited 1 time in total.
Not sure why you would need to wire the filter cover screws. There's more of an issue with them sticking than backing out.
Maybe the PO wanted to save the threads (or had damaged them in the past) by using extremely low torque.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
x
Do I see rust on the valve retainer and, perhaps, on the valve spring? If so, I would be a little bit nervous and might want to see a bit more inside the engine before just assuming everything is fine. The rust on the outside shows that it has definitely been in a fairly moist environment.
x
Last edited by Deleted User 62 on Fri Jun 10, 2011 11:19 am, edited 1 time in total.
