I've been looking at an old ,rather derelict R65 and wondering about uses or the possibility of a rebuild .
How many mph or km per h does an R65 do per 1000 rpm , just so I can compare it to my ST .
R65 mph / km per 1000 rpm ?
- Sibbo
The Grateful Dead
The Grateful Dead
Re: R65 mph / km per 1000 rpm ?
As requested by NC Steve, I went out today and got some speed readings from my GPS receiver and noted the engine speed.
Due to weather conditions, I couldn't take it much above 75, but it appears that 5th gear is 500 RPM for every 5 MPH.
This is a '79 R65 with a 31/9 stock final drive, and Bridgestone Spitfire tires.
3rd gear
30 mph (48.27 kph) = 3000
35 mph (56.30 kph) = 3500
40 mph (64.36 kph) = 4000
4th gear
45 mph (72.40 kph) = 3750
50 mph (80.45 kph) = 4000
55 mph (88.50 kph) = 4750
5th gear
55 mph (88.50 kph) = 4000
60 mph (96.54 kph) = 4500
65 mph (104.59 kph) = 5000
70 mph (112.63 kph) = 5500
75 mph (120.68 kph) = 6000
3rd gear
4th gear
5th gear
- Sibbo
Wow ! that was quick !
Thanks very much Rob , it appears that an R65 is quite a bit lower geared than my ST .Possibly more than I would prefer ,after my ride today I have to admit I'd really like a higher 5th on the ST .
R65 final drive .1: 3.44
ST final drive. 1 : 3.36
The Grateful Dead
The Grateful Dead
I am pretty sure that all 3 generations of R65 ('78-'80, '81-'84 and monoshock) had different final drive ratios.
BTW, that post was from a few years back on the R65 forum, hence the quick reply.
- Sibbo
Still quick !
The Grateful Dead
The Grateful Dead
- enigmaT120
I don't remember the rear end ratio of my R65 but I think it's higher geared than Rob's. I think 4,000 rpm is nearly 60, 5,000 is around 70, and 6,000 is a bit over 85 which is as high as mine used to read. I've had it up to about 7200 rpms a couple of times just to see if it would do it.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
And keep in mind Sibbo, my road speeds were measured using a GPSr, while Ed's are most likely with the Motometer.enigmaT120 wrote:I don't remember the rear end ratio of my R65 but I think it's higher geared than Rob's. I think 4,000 rpm is nearly 60, 5,000 is around 70, and 6,000 is a bit over 85 which is as high as mine used to read. I've had it up to about 7200 rpms a couple of times just to see if it would do it.
I did see a '82 on eBay - it had a 32/9
http://cgi.ebay.com/ebaymotors/BMW-Fina ... 0507159480
- Sibbo
That's about 6% higher than the norm ,that would be good !
The Grateful Dead
The Grateful Dead
