My /5 horn is dead, HELP!
Unclviny
Post by Unclviny »
I need either a new horn (that looks right!!) or rebuilding tips, no twin Freeway Blasters for me because I cannot hide them.
Any idea's?
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
Deleted User 62
Re: My /5 horn is dead, HELP!
Post by Deleted User 62 »
Vince, the Bus Depot sells Hella horns with bracket for around $10, and aftermarket for $6: http://www.busdepot.com/details.jsp?par ... 111951113B That being said, are you sure it's the horn and not the switch?
Unclviny
Post by Unclviny »
Yes,
The wiring tested good all the way, I will go check that site now.
Thanks
Vince
1952 Triumph TRW
1936 BMW R2
How do you know that the horn is actually bad? Did you hook it up directly to a good battery?
Unclviny
Post by Unclviny »
I have not tried it on a battery (or a 12V power supply) but the wiring tests good to the horn and the horn has been "hit or miss" (working intermittently) since I got the bike.
Vince
1952 Triumph TRW
1936 BMW R2
wirewrkr
Post by wirewrkr »
Unclviny wrote:I have not tried it on a battery (or a 12V power supply) but the wiring tests good to the horn and the horn has been "hit or miss" (working intermittently) since I got the bike.
Vince
Hit or miss still means nothing.
Hook up a battery to the horn. It doesn't get any easier than that.
Also, some horns have an adjustment screw on the back that can cure the intermittent woes if they are in fact the fault of the horn.
templetommy
Post by templetommy »
Had the same problem the adjusting screw did the trick
Templetommy
73 R75/5
Templetommy
73 R75/5
George Ryals
Post by George Ryals »
Open up the horn and clean the points (contacts).
Smile it's contagious!
'85 R80RT wreck for parts
hudson
Post by hudson »
also, make sure horn wire from switch is not pinched anywhere along its travels to the horn itself...
