Omega ignitions failing.........
blitz
Re: Omega ignitions failing.........
Post by blitz »
One way to do it is use a magura cable clutch/hydraulic clutch converter. This is designed primarily for off-road motorcycles: http://www.amazon.com/2003-2009-YAMAHA- ... B000MQ8FWW
pmonk
Post by pmonk »
Two failures with bikes that use a switch to go back and forth. Could there be a problem with this method of use?
I didn't use a switch. I had a separate wires for the condenser and the Omega. When mine died I was able to disconnect the wire to the omega and unplug the wire from the omega and plug in the wire from the condenser to the right side coil. I got about 10k miles out of mine which isn't too cost effective. Also my high speed idle is gone now. The bike idles very smoothe on the points. On the Omega after the bike got warm my idle speed would increase, so I have to assume that things were not exactly right with it for quite a while.
Norm T R100T R1150RT
Post by Norm T R100T R1150RT »
Guess I'm lucky - knock on wood - I've got 40,000 plus miles on mine - no problems. I do carry my bean can with me just in case . . . if I do have an Omega failure I could use a little help - if you please, anyone - (faded memories, along with a water soaked wiring diagram) - all I need do after installing the "can" would be to disconnect the wire at the "Z" terminal on the Omega and attach it to the condenser ? thanks - Norm
Norm Taylor
1980 R100T Airhead
2002 R1150RT Oilhead
1950 HD Panhead
Southern Maryland, USA
2003 K1200 GT
mattcfish
Post by mattcfish »
pmonk wrote: On the Omega after the bike got warm my idle speed would increase, so I have to assume that things were not exactly right with it for quite a while.
One of the tricky things with the Omega is that it begins to advance at only1000 rpm. That means if you set your idle speed close to that when cold it will idle fast when heated up because the timing has advanced.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
mattcfish
Post by mattcfish »
Omega Ignitions are still available from the German supplier. You need to contact them directly using the following methods below. I'm not sure what's up with the Canadian distributor, but the German Company says they are still available....I can't get any information about the future of the units though. Maybe one of our German/European members could call them and speak to someone directly.
I did not have any trouble ordering an ignition via email back in March. Like I said before, it was actually about $80.00 cheaper and didn't take any longer to get to the US than the previous Canadian orders I placed. Not sure about spare parts....
OMEGA-OLDTIMER - E.Breindl-Grope - Querumer Straße 26a - 38104 Braunschweig - Germany
Tel.: (49)0531-375737 - Fax: (49)0531-377763 - e-mail: info@omega-oldtimer.de
ALL IGNITION SYSTEMS ARE PREPARED TO USE THE ORIGINAL COIL, SPARKS AND OTHER ORIGINAL EQUIPEMENT.
IT IS ALSO POSSIBLE TO ORDER THE IGNITION SYSTEMS COMPL. WITH NEW COILS – OR IN A TWIN SPARK EDITION.
ALL PRICES ARE INCLUSIVE SHIPPING (shipping is included in the figure!) FOR ONE IGNITION SET (2010):
EUROPE (includes VAT+shipping) WORLDWIDE (Includes shipping)
BMW R25,R26 – WITHOUT COIL - NO:12.14.8030.398 – 189,90 EURO - 169,90 EURO
BMW R25,R26 – WITH COIL - NO:12.14.8030.399 – 249,90 EURO - 219,90 EURO
BMW R27 - WITHOUT COIL - NO:12.14.8030.400 – 269,90 EURO - 229,90 EURO
BMW R27 - WITH COIL - NO:12.14.8030.401 – 309,90 EURO - 269,90 EURO
BMW R2,3,35 – WITHOUT COIL - NO:8M.67.G999.00 – 119,90 EURO - 109,90 EURO
BMW R2,3,35 - WITH COIL - NO:8M.67 G999.10 – 149,90 EURO - 129,90 EURO
BMW R45,65 – WITHOUT COIL - NO:12.14.8030.877 – 179,90 EURO - 159,90 EURO
ALL ->1981
BMW R45,65 – WITH COIL - NO:12.14.8030.878 – 249,90 EURO - 219,90 EURO
ALL ->1981
BMW R/5-/7 - WITHOUT COIL - NO:12.14.8030.877 – 179,90 EURO - 159,90 EURO
ALL ->1981
BMW R/5-/7 - WITH COIL - NO:12.14.8030.878 – 249,90 EURO - 219,90 EURO
ALL ->1981
BMW R45-100 - WITHOUT COIL - NO:12.14.8030.898 – 189,90 EURO - 169,90 EURO
ALL 1981->
BMW R45-100 - WITH COIL - NO:12.14.8030.899 – 259,90 EURO - 229,90 EURO
ALL 1981->
BMW R/5-/7 - TWIN SPARK - NO:12.14.8030.887 – 229,90 EURO - 199,90 EURO
ALL ->1981 WITHOUT COIL
BMW R45-100- TWIN SPARK - NO:12.14.8030.888 – 239,90 EURO - 209,90 EURO
ALL 1981-> WITHOUT COIL
BMW R… - DOUBBLE COIL - NO:12.14.8030.515 – 89,90 EURO - 79,90 EURO
PAYMENT IS POSSIBLE BY BANK TRANSFER OR PAYPAL OR CREDIT-CARD !
SHIPPING IN EUROPE ABOUT 3-5 DAYS – OVERSEA 5-10DAYS
IF THERE ARE ANY QUESTIONS – PLEASE CALL 0049 – 531 –37 57 37 !
THANK YOU FOR YOR ATTENTION !
OMEGA-OLDTIMER
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
