Well, to sum up.
Real OEM is saying it's the same part # now.
Duanne says no.
Vansen is drunk, or hung over? Or just angry.
I know that 40 140mm spokes is the same, but I was wondering about something like Duanne says, the head system....
Will these spokes work?
Re: Will these spokes work?
'74 - R90/6
Too bad Lonnie is not around anymore. He'd straighten all you guys out.
I seem to recall from his wheel building page that the /2 spoke hub ends are different from the /5.
http://agwalker.com/wheelbuilding.htm
Ah Lonnie - those were the good old days.Native /5 wrote:Too bad Lonnie is not around anymore. He'd straighten all you guys out.
All of the Earles fork models had spokes that required a collet piece to hold it from turning. So, one needed 40 of each; collets, spokes and nipples. It really was a great system.Native /5 wrote:Too bad Lonnie is not around anymore. He'd straighten all you guys out.
The first two years of the /5 used a spoke with smaller shoulders than the /2. They broke often at the heads. if the shoulders weren't exactly the same height, the head would be forced to tilt a bit. Then they would break off.
There was an easy way to make them work, but few wanted to go to the trouble to "set" them with a punch and retighten the nipple.
I know, more than anybody wanted to hear.
~Rob - sitting enraptured at the master's feet...Duane Ausherman wrote:I know, more than anybody wanted to hear.
Drunk ? Perhaps. Hungover ? Not a bit. Angry ? Never.pkboxer wrote:Well, to sum up.
Duanne says no.
Would I trust Duane's take on spoke fitment ? ABSOLUTELY !.
They should, but why not buy from a reputable source for not much more? Who knows where aftermarket spokes are made? Huckys sells the same part number spoke for all 18" wheels, /2 -/6.pkboxer wrote:http://cgi.ebay.com/ebaymotors/ws/eBayI ... AUS%3A1123
Will these work for a /6 rear wheel?
They are both 40 - 140mm spokes, but is there a difference in the /2 type spoke?
Thanks
Tim, I agree, buy from a trusted source. Do you want them to stay in business? Support your favorites, even when it costs a bit more.
