90S pistons : opinions sought!!!!!
hools100RS
Post by hools100RS »
G'day!!! How do I get myself into these dramas!!!? :roll:
I recently bought some standard size, good condition, 90S pistons off AUS Ebay and presumed that they were the same size, weight, etc. Wrong!!! The pistons are a 89.970mm (3.5421") 'B' bore code and a 89.980mm (3.5425") 'C" bore code. Both have different weight designations (+ and -). I have two new standard bore barrels, 'C' bore code 90.020mm (3.5441"). Can I? should I? use these pistons in these barrels? The standard piston clearance for the /6 is 0.035-0.045mm (0.0014-0.0018") and the maximum permissible piston/cylinder clearance: 0.120mm (0.0047") which I figure gives me a bit to play with on the 'sloppy ' 'B' bore. Am I stressing too much!!! ?
The pistons came with new rings which more than offsets the cost of the pistons if I can't use one. If I was to weigh each piston ( haven't yet) and determine the difference, is judicious filing of the weightier of the two (from the inside somewhere!!!) accepted equalizing practice??? Any thoughts, comments please!!.............. hools.
George Ryals
Re: 90S pistons : opinions sought!!!!!
Post by George Ryals »
Filing/grinding/machining weight off the wrist pin boss to match the other piston is the way it is done. I'd use the B piston in the C cylinder and forget it. The B piston is only .0004" smaller than the C piston.
Smile it's contagious!
'85 R80RT wreck for parts
vanzen
Post by vanzen »
George Ryals wrote:Filing/grinding/machining weight off the wrist pin boss to match the other piston is the way it is done. I'd use the B piston in the C cylinder and forget it. The B piston is only .0004" smaller than the C piston.
Accurately measure each cylinder and each piston –
Measuring & matching may result in 2 assemblies that will be within operational tolerance.
If you're not too particular, you can probably get away with using them. Many manufacturers don't go to the bother of 'A', 'B' and 'C' grading pistons at all. I would say the weight variation is more important (if a smooth engine is what you desire).
Rob Frankham wrote:If you're not too particular, you can probably get away with using them. Many manufacturers don't go to the bother of 'A', 'B' and 'C' grading pistons at all. I would say the weight variation is more important (if a smooth engine is what you desire).
Because, as I understand, flat motors tend to be more prone to piston slap, BMW's more careful matching of clearances was likely to help control that issue. Certainly running one piston size "too small" in the letter grading would be a very slight change in clearance. Going one size too big could possibly be a lot bigger deal.
mattcfish
Post by mattcfish »
I've found more deviation in clearances on aftermarket VW pistons (from the same set) than that. The main thing to check is the ring gaps.
Be careful removing weight from pistons. There are only a few spots you can safely remove material without weakening the piston. You may just be able to put the heavier con rod on the side with the lighter piston. You are going to change your big end bearings while you're in there, right?
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
vanzen
Post by vanzen »
If you will be "lucky"
You may have a letter coded cylinder at one end of it's tolerance limit
and a piston at the other end of it's limit.
I have seen some "mismatches" that will fit together better than stock issue ...
Bottom line:
Don't speculate – MEASURE.
hools100RS
Thanks Vanzen!!! Yes I'd hope that I'm lucky but yes, I will measure and make a final decision on the smaller piston before proceeding. Thanks guys for your insightful and postive vibe..... I was unsure in unfamiliar territory. Mattfish, I'll be changing bigend bearings whilst I'm in the vacinity!!!! and weight matching the pistons and rods didn't occur to me, I might get out of it without having to remove any excess.... cheers, hools!!!
I can't go along with that because BMW do (or at least did) it for all their engines, car or bike, flat or vertical. I guess its just one of them BMW thangs...
Re: How about space age coatings?
Post by Chuey »
Yesterday, I wrote up a response to this thread before there were other responses. I clicked a wrong button and it was lost. Part of the response regarded coatings applied to reduce friction. They are applied to the piston skirt, usually by a powder coater specializing in automotive work. I think they may add the tiniest amount of dimension. It sounds like it may be worth looking into in this case.
Years ago, I had heard of knurling piston skirts to grow them dimensionally. I do that on the headset fork crown race area of bicycles to make loose crown races fit tightly. The knurling of piston skirts is where I got the idea. It works great.
