You sound like my missus Garnet, speak fer yesself.Garnet wrote:
That whole inny outty thing is over rated.
Loose rivets...rear wheel spline cup
Re: Loose rivets...rear wheel spline cup
My splines actually separated from the wheel at freeway speed. All the rivets popped loose on an upshift. Instant neutral in all gears. That was about 20 years ago. I repaired the problem by drilling the holes out and putting in 7mm bolts with nuts on the outside of the wheel. I ground a portion of the heads off so they fit flush against the hub. The bolts are tight to this day, no issues what so ever.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
I agree with what Major Softie said about the ovalization not being likely if they are not all loose. I would peen the loose ones and maybe give the other ones a warning tap to make sure they know better than to come loose.
