Check that guide ring O.D. for wear as it can be the cause of the leak. I know.
The guide ring O.D. can be 'ground' or 'turned' to remove any imperfections that may cause a leak.
I had my guide ring 'ground' about 15 years ago after replacing the seal without success. Leak stopped.
I had the same guide ring 'turned' about 5 years ago. No leaks today.
special tools & how to improvise....
Re: special tools & how to improvise....
in my case there wasn't a leak. I'm rebuilding a bottom end and everything is getting replaced. Hopefully the guide ring wont need such a thing but thanks for the info, never heard of anyone getting the rear main seal surface refaced....
My middle name!Matt wrote: never heard of anyone.......
Something like this:Kurt in S.A. wrote:If you have the flywheel off, I think for any reason, there is a danger of the crank moving forward. It takes a few minutes to block it. Usually people put something fairly small that plugs into the forward hole on the alternator bolt so it sits maybe 0.5" proud of the bolt, and then slip the engine cover back on until it's snug. You could also rig up a 2x4 that is held back by wrapping roping around the board and the jugs. If the crank moves forward, you'll not be having a fun day!!
But this rig will still NOT ALLOW YOU TO USE THE CRANK as a fulcrum in prying out the seal.
1975 R90/6
1979 R65
1979 R65
thanks for the help everyone, I haven't wrenched on Airheads seriously in a some time.
- enigmaT120
So that's what happened to them! I was blaming my wife or the wood rats.Duane Ausherman wrote: Often an old BMW part was used to make a tool. I have only used a few of Ed's tools, but there were all good.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
Is your claw hammer missing?enigmaT120 wrote:So that's what happened to them! I was blaming my wife or the wood rats.Duane Ausherman wrote: Often an old BMW part was used to make a tool. I have only used a few of Ed's tools, but there were all good.
I started in the bike industry under an older Schwinn trained guy. He'd not permit claw hammers in his presence. "We're not wood butchers, son." Adjustable wrenches were called "Crescent hammers."Chuey wrote:Is your claw hammer missing?enigmaT120 wrote:So that's what happened to them! I was blaming my wife or the wood rats.Duane Ausherman wrote: Often an old BMW part was used to make a tool. I have only used a few of Ed's tools, but there were all good.
So, you were metal butchers...melville wrote: I started in the bike industry under an older Schwinn trained guy. He'd not permit claw hammers in his presence. "We're not wood butchers, son." Adjustable wrenches were called "Crescent hammers."
