Are these a good idea?
Unclviny
Re: Are these a good idea?
Post by Unclviny »
I did the LED-THING (turn signals) on my /5 and undid it pretty quick, they are no brighter and they did not draw enough to "trip" the flasher relay so I had to change that too and the indicator would not work with them.
I did install a "dancing" brake-light-LED and that is GREAT! (it flashes 4 times and then stays on every time I hit the brakes).
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
Deleted User 287
Post by Deleted User 287 »
It still utilizes the OEM bulb socket, which is a weak point on a lot of airheads.
I like my Beacon 2 from Rick at Motorrad Elektrik much better. I was constantly removing my taillight lens to reset the bulb in it's socket. Now there is no more socket.
Turn signals Vince? This is a brake light - no flasher relays involved. Anyone that tries to upgrade to LED turnsignals is just someone looking for something NOT broken to fix.
Unclviny
Post by Unclviny »
I got my LED brakelight from roadrocketeer, they have a reputation for great products and miserable service, luckily for me things went well. It has a dipswitch on the board and it has 8 flash-patterns, it took a little work with the schematic to make it work as the directions say "simply swap the 3 wires over" (sounds easy right?) but there are like 9 wires!
Vince
1952 Triumph TRW
1936 BMW R2
vanzen
Post by vanzen »
LED tech is quickly becoming the industry standard
and has been readily embraced by auto and MC manufacturers alike, BMW included.
This, even as those philistines will staunchly maintain their doubts and misconceptions,
emphatically, if not irrationally, struggling to cling onto the past ...
Retro-fit gizmos and do-dads, however, should be approached with extreme caution ...
vanzen
Post by vanzen »
justoneoftheguys wrote:...It still utilizes the OEM bulb socket, which is a weak point on a lot of airheads...
The integrity of "sockets" (connections, and grounds)
will be the nemesis of any 20+ year old machine that will depend upon electric lighting !
Clean and tight – a bulb-socket works just fine.
Once neglected for a decade or three or so ... then blame will be too easily displaced,
dougie
Post by dougie »
Like Rob, I have the Beacon 2.
Very effective and reliable, but more money.
jagarra
Post by jagarra »
You're correct in that the sockets and connectors will be your nemesis. I worked in the electronic and computer repair business for over 40 years. In determining what would fail we used to used a process called failure trending analyisis, which predicted what would fail as a % of faults. The items that were always the highest were connectors and sockets.
As these bikes age, the probability of failures in these areas will increase.
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
Seth
Post by Seth »
I love my toxic old Cyberlite!
Not legal, but when did that stop us.
It flashes in proportion to how hard you're braking (assuming level ground).
