boxertwinjeff wrote: Is there any technique to riding on Gravel roads ?
Stay out of the deep stuff.
Don't try and break hard going around corners.
Higher revs in areas of uncertainty.
Watch out when crossing the centre mound between two wheeltracks, it can be deep.
Travel at an appropriate speed for the given situation, 15-170 kph is good
Hard braking is possible (in a straight-ish) line where loose material is minimal, usually in a wheeltrack.
Don't try to alter your course abruptly at speed.
Be prepared to GAS IT to recover control/maintain control/know you're alive!
All the above can be encountered in 1 klm.
