R100RT gas tank filler cap issue.
luckyjohn
Post by luckyjohn »
Good morning all.
I have started a restoration on a '79 R100RT.
The gas tank filler cap and its threaded tank attachment rotate together when I try to remove the cap.
Does anybody know of a non-invasive remedy?
Thank you.
John
Deleted User 62
Re: R100RT gas tank filler cap issue.
Post by Deleted User 62 »
If you are saying you can't remove the cap, put a loop of rope through the handle and give it a sharp upward jerk. It should come out.
luckyjohn
Post by luckyjohn »
Thanks Tim.
I'll give that a try.
The male and female halves, including the gasket, rotate together when I unscrew the cap. My gorilla-grip assistant can stop the gasket from rotating but the cap still does not unscrew.
Time to use brute force.
dougie
Post by dougie »
This might be of some help.
http://www.largiader.com/articles/gascap/
When you get it out, see Anton's bit on the holes and putting something in there to stop the rotation. I've had caps like that for years. Occasionally it's wise to ensure the bits you put in there are still there, but it does prevent the spinning cap scenario.
luckyjohn
Post by luckyjohn »
Thank you all for the links to the ratcheting gas cap removal/repair.
This crowd flat gets after it.
Many thanks.
John.
dougie
Post by dougie »
luckyjohn wrote:Thank you all for the links to the ratcheting gas cap removal/repair.
Many thanks.
John.
And now Luckyjohn you need to be lucky. :mrgreen:
