Crankcase studs
Crankcase studs
Could some one remind me again where the two shorter crankcase studs go and is there an installed length?
Re: Crankcase studs
Tom Cutter wrote:
"9-7/8 (9.875") to 9-15/16 inches (9.9375") or (250.8-252.4 mm) from the case gasket surface to the end of the stud."
So it looks like RealOEM says there are 6 that are 275 mm long and 2 that are 297 mm long (this is for a /7). You mentioned 2 shorter ones? I suspect the depth of the holes in the crank case will indicate where the longer and shorter ones go.
Re: Crankcase studs
Yes sorry - two longer ones.
