This is the vehicle in question. My nephew made it from his trashed 2002 Suzuki GSXR750.
Cable actuated clutch.
He did admit to me last night that he had to make his own clutch cable, which he did from a length of plumbing snake covered with heat shrink tube. So no, no teflon inner sleeve on this one...
And yes, the powertrain has been abused since the conversion. He built it because the bike's frame was broken on one of the large spars up on top by the gas tank on one side. He did this as a lark.
Now, it acts as if the clutch won't release. When it is in gear, the rear wheel is turning regardless of the position of the clutch lever.
Mind you, this is VERY much a bodge job, and right now he doesn't even have a working clutch pedal up front. He is just pulling on the end of the cable with a pair of locking pliers.
In his first act of desperation, he ordered a clutch kit and installed new plates and springs. It made no difference.
It is VERY likely that he destroyed the transmission in his shenanigans. He was constantly having heating issues on the engine due to the stock location of the radiator. But the engine still starts easily and responds to throttle well.
I took a couple of pictures for visual reference, but those of you who might be able to help me won't need them.
This first one is the clutch throwout pushrod from the left side of the engine. It goes through the gearbox to the clutch on the right side. I saw the throwout bearing & races last night, everything looked good.
This one is the cover that goes over the push rod. It contains the actuator that is a ramp system to transfer the rotational energy into lateral.
The tip of the push rod goes into that hole. We have not taken this assembly apart any further, although it can be.
So what do you guys think? Is it time for the recyclers? (I do.)
UJM Gearbox/clutch Issues - 2002 GSXR750
- Steve in Golden
Re: UJM Gearbox/clutch Issues - 2002 GSXR750
I think it looks like a deathtrap.
Sorry dunno what to tell you on the clutch problem.
- enigmaT120
I don't think you could activate a cable-operated clutch without the help of Archimedes.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
Yeah, it was just an exercise in welding, a see-if-he-could-do-it kind of thing.Steve in Golden wrote:I think it looks like a deathtrap.
He wants to sell it, but would like it to be run-able, first.
He has only tipped it over once...
justoneoftheguys wrote:He has only tipped it over once...
So far......
Hence he wants to give it a quick paint spray and unload it on some poor sucker.Major Softie wrote:justoneoftheguys wrote:He has only tipped it over once...
So far......
I would want a professionally written disclaimer to go along with the sale, I think.
Oh my. Probably best immobilized.
Put the clutch mystery down to divine intervention.
