On the ribbed rear drives that I have, they have a steel sleeve surrounding the stud. The sleeve is 15mm in diameter and sits proud about 1.5mm of the spot faced surface allowed for the shock.
Garnet is right. Though, mine will look a bit different. I'll share a picture when it is further along.
PS (edit) Any guesses as to what the structure is made of?
Rear drive question:
Re: Rear drive question:
There is this one
http://www.flickr.com/photos/presspix/3 ... otostream/
Edit: and this
http://www.flickr.com/photos/jano2106/3 ... otostream/
Edit: and this
Chuey wrote:Has anyone here removed the stud to which the rear shock is attached? How would that be done? How is it retained in the unit?
Final drive in question: 1983 R100
Thanks,
Threaded in, will simply come out with two nuts locked against each other.
Thanks, Garnet and Stephan. That's what I needed to know. Onward!
By the way, those three pictures were very inspirational!
Chuey wrote: Chuey
You are NOT building a rear suspension out of wood!
are you?
Deleted User 72
are you?
Deleted User 62
Is it just me, or does the lower mount for that shock look like a failure waiting to happen? The shock should be mounted in line with the U-shaped piece, IMO.Garnet wrote:
Sure would be better.
- Jeff in W.C.
You mean more like what Vanzen did or is doing. I hope he doesn't mind me posting the photo from his site. It is available for anyone to see on his site.Tim Shepherd wrote: Is it just me, or does the lower mount for that shock look like a failure waiting to happen? The shock should be mounted in line with the U-shaped piece, IMO.
There's more on his site.
http://www.framecrafters.net/show-project.php?id=35
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
1988 R100 RT
2018 R1200 GS
Deleted User 62
That's better still, but if it was mine I'd want it in line with the brace, not attached to the top of it.
Last edited by Deleted User 62 on Thu Sep 27, 2012 9:32 pm, edited 1 time in total.
