r90/6 aluminum spring covers on a Ikon Shock
jgleadle
Post by jgleadle »
I just replaced my factory shocks on my 74 r90/6 with ikons, i really want to keep the factory look. how can i switch over the factory parts to the ikon's. is the factory hole in the covers, larger or smaller then the ikon's
Deleted User 72
Re: r90/6 aluminum spring covers on a Ikon Shock
Post by Deleted User 72 »
The hole is smaller than required for the IKON (Koni) shock. It can be enlarged with a hole saw, carefully. You'll need a way to hold the cover rigidly in place while drilling with a press.
chasbmw
Post by chasbmw »
If you bugger up the job, then there people who sell stainless steel covers sized for Ikons
Charles
1975 R90/6
mattcfish
Post by mattcfish »
There's also a bunch of us with old Boge shocks lying around in the parts piles. You mean there's a market for this stuff. I proved the wife wrong once again. I'll keep hording.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
Post by Garnet »
mattcfish wrote:There's also a bunch of us with old Boge shocks lying around in the parts piles. You mean there's a market for this stuff. I proved the wife wrong once again. I'll keep hording.
You can't have too much junk many spares.
2valve
Post by 2valve »
jgleadle wrote:I just replaced my factory shocks on my 74 r90/6 with ikons, i really want to keep the factory look. how can i switch over the factory parts to the ikon's. is the factory hole in the covers, larger or smaller then the ikon's
hi, im pretty sure that the OE shrouds will " not " fit the ikon /koni shocks , well they didny fit on my koni shocks so i had some marine grade alloy shrouds spun up to look like the OE part.
Post by Garnet »
If you have the $$, scroll down this page.
http://www.bmwhucky.com/010033.html
