no neutral light
montmil
Re: no neutral light
Post by montmil »
Might you utilize a test lamp between the two terminals on the neutral switch? Tough to reach, for sure.
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
We found that those connectors could be removed and installed with a dentist's tool for pulling teeth. It is still tough.
Duane Ausherman wrote:We found that those connectors could be removed and installed with a dentist's tool for pulling teeth. It is still tough.
Yep, they can, but the tool to use is a Magills forcep, which also works great if you're doing electrical work in the headlight.
Foerster sponge forceps are beefier and might be a good option. They'll do the headlight wiring to.
hal
Post by hal »
My '74 r90 had two wires on the box when I gor it but I still had to change the switch when I changed to a newer (still post '81) box. So I guess there where at least three different switches.
Hal
'74 R90/6
'97 R850R
derek1922
Post by derek1922 »
I don't think it's the switch in the gearbox,the paperclip thing should have worked with the neutral switch taken out of the equation,I've trawled the internet and as far as i can work out the diode has gone bad in the starter relay,I'll send for a new one and if it isn't the problem then I'll still have a spare relay.
Thanks for your replies.
derek1922
Post by derek1922 »
Got the neutral light working,it was a two part fault,I switched out the starter relay which was the first fault and also there was a faulty earth at the switch at the gearbox.
This might help others if they have the same problem.
