91 r100rt carb setup
sprints@pldi.net
Post by sprints@pldi.net »
Does anyone know the original jetting and needle position for a 91 R100rt?
I'm going to clean my carbs and want to see if everything's setup right. Thanks - Rod
robert
Re: 91 r100rt carb setup
Post by robert »
The only thing I commit to memory is where i keep the manual and notes with all the specs.
sprints@pldi.net wrote:Does anyone know the original jetting and needle position for a 91 R100rt?
Email sent. You'll need to know your carb numbers when looking at the specs.
chasbmw
Post by chasbmw »
Check to see whether it is a 32 or a 40mm carb, some late euro airheads had 40mm carbs, but this might have been restricted to GSs
Charles
1975 R90/6
Jean
Post by Jean »
BING book that I got in 2009 shows ALL carbs for R100 ending with 103 thru 126 as being 40mm.
What's the carb number ?
Nearest I can find for R100RT is a 64/32/363 & 4
135
2.66
45-251
3rd
45
3/4 -1 turn out
Hawksley shows the R100 RT and RS monos as being 32's, with the carbs barry shows. They show the GS, the R, and the Mystic as 40's: 94/40/123 - 94/40/124.
Seems odd...
