bent forks R75/5
chasbmw
Re: bent forks R75/5
Post by chasbmw »
Yes, 82-84
Photo of the machined damper rods
Charles
1975 R90/6
Bamboo812
Post by Bamboo812 »
Thanks! Just to confirm, it's part # 31 42 1 241 649 "guide ring" correct? Image
chasbmw
Post by chasbmw »
That looks like it
Charles
1975 R90/6
Bamboo812
Post by Bamboo812 »
Another question Charles, do you recall if the groove was just machined wider to fit the new ring, or was it also made deeper as well? It's the last thing we need to do to get my friends R100/7 back on the road!
chasbmw
Post by chasbmw »
I think that the groove was not deepened, I would machine it wider to take the plastic ring and then fit. On my bike it's a fairly loose fit, the ring not compressed much.
Charles
1975 R90/6
daz
Post by daz »
Ok, so probably a dumb question: So why not decrease the width of the new plastic ring? I have to believe that would require less machining than the steel damper rods. Maybe even use abrasive paper on a sheet of glass for the plastic.
1971 R50/5, 1980 R100T,
CRF 300 Rally, CRF 250F,
1947 James ML
chasbmw
Post by chasbmw »
Charles
1975 R90/6
Bamboo812
Post by Bamboo812 »
daz wrote:Ok, so probably a dumb question: So why not decrease the width of the new plastic ring?
I think the plastic (nylon?) rings are wider because they will wear faster than the thinner steel rings.
bbelk
Post by bbelk »
Airbear wrote: a bingle with a cow
I liked the way that sounded so much that I had to google it and I will be forever greatfull because I found this:
1975 R90/6
1979 R65
Ahhh...Lara! An airhead in the vacuous sense! There are other similarities to our favourite bikes too! :lol: ;)
