Re: Sequential shifting question for the cycle racers...
Posted: Sat Nov 27, 2010 7:37 am
No, not really. Up-shifts in sequentially shifted race car boxes are simply cluthless, downshifts mandated a clutch and matching (or coming close) the speed of the motor and the drive-train by heel and toe technique (as is mentioned, "blipping the throttle") to select each lower gear.Chuey wrote:Are you asking why we don't double clutch the bikes?
I am truly only aware of having to actually "double-clutch" transmissions that are not sequential, both straight cut (think a semi tractor) or a synchronized box that has no synchronizers left. I do not know how you would double clutch a sequential as you need a neutral to truly do it.
1) Clutch in.
2) Select neutral.
3) Clutch out.
4) Hit the gas (optional; depends on why you are doing it and in what; may not be needed in a broken synchronized transmission...)
5) Clutch in.
6) Downshift.
This would truly be double-clutching. Ask any trucker, they know all about it.
