THOSE SEALS AROUND...oops,...the pistons can deteriorate and split. Probably worth changing them every 15 years or so!
Leaking caliper
Re: Leaking caliper
Re: Leaking caliper
I'm still on original 79 seals and they seem fine. There is still enough hysteresis in the rubber to pull the pistons back and have the wheel spin free.
Re: Leaking caliper
This world has too much hysterics!
Do you have a dual disk set up?
Re: Leaking caliper
Single disc with Ate caliper.
Can't see why the seals shouldn't work the same on dual disc. Only difference is they push twice as much fluid back into the master cylinder reservoir.
Re: Leaking caliper
That's a much different caliper, and with two discs rubbing I would imagine any drag would be increased.
Re: Leaking caliper
It's a dual piston Ate caliper so very similar to a Brembo.
If there is drag from the pads then I suppose dual discs are bound to make it worse. If the drag is zero then 2 x zero is still zero. That wasn't my wheel spinning video but mine does behave the same and will spin for close to a full minute so zero drag or close to zero drag is possible.
Re: Leaking caliper
Our brakes need all the help they can get.Zombie Master wrote: ↑Sun Jul 09, 2017 8:31 pm That's a much different caliper, and with two discs rubbing I would imagine any drag would be increased.
Re: Leaking caliper
That was my '79 R65 in the video, Barry.barryh wrote: ↑Mon Jul 10, 2017 6:12 am It's a dual piston Ate caliper so very similar to a Brembo.
I just think those '79s were freaks of nature.
