As my airhead gently weeps
Wobbly
Re: As my airhead gently weeps
Post by Wobbly »
richard t wrote: Wed Sep 20, 2017 9:41 pm On the /6's the ring on the push rod tube is movable, I have a tool to tighten it against the seal, some times it will stop the leak until you get time to change the seal. If the rubber is rock hard you gonna have to change the seal.
I agree. On the /6 and /7 machines I'm familiar with, the chrome push rod tube is pressed into the cylinder. The push rod seal is a large block of synthetic "rubber" which, through the material quality of being "springy", works by pushing against both the tube and the engine case, thereby effecting an oil-tight seal.
As these seals naturally age harden due to heat, soap, UV, etc, their springiness starts to wane. The drift shown is typically a homemade tool that allows the push rod tube to be driven out of the cylinder 1 or 2mm to restore the seal's tight fit with the engine case.
It's a temporary measure, since the real culprit is the hardened push rod tube seal. But I agree... if the engine is running really good... then don't mess with it. Do the rings, seals, and valves all at one time. Much better to 'kill 2 birds with 1 stone.'
The top end job is expensive, but the real BMW parts are worth the price. The wise thing to do is to start stockpiling gaskets and seals over the next few months, so that you don't have the full expense at that future date. ;)
I've got all the gaskets for a top end re-seal, though I bought them from Moto Bins and am a bit concerned that they might not be the best parts to install. I had a terrible time with their caliper re-build kits, and ended up having to buy an OEM kit that went in with no problem. Turned out that I didn't need to rebuild the calipers anyway:(
Post by Rob »
So, I guess that we in the USA are blessed that Moto Bins does not ship here?
George Ryals
Post by George Ryals »
I bet it is the oil pressure switch!
George Ryals wrote: Thu Sep 21, 2017 5:24 pm I bet it is the oil pressure switch!
I'll check that out...thanx!
Can I pull off that switch when the bike is full of oil. How is the switch sealed?
Zombie Master wrote: Thu Sep 21, 2017 7:15 pm
Yes, you can pull it off when the sump is full. The switch is on an oil galley above sump level.
My /6 had a crush washer and straight threads on the switch. Some might have pipe (tapered) threads like an ACVW.
richard t
Post by richard t »
you are right, only works on the older bikes. Airbear's picture looks right. Mine has a numbers on it.
Thanx Mel! I'll do some checking to see if that switch is leaking. I've got a long 24mm impact socket. Anybody know what size gasket would be on that switch?
Rob wrote: Thu Sep 21, 2017 2:18 pm So, I guess that we in the USA are blessed that Moto Bins does not ship here?
That'd be Motorworks Rob.
