Page 2 of 3
Re: Painting snowflake wheels.
Posted: Fri Apr 27, 2018 6:57 pm
Oh yeah, he pulled my boot off he was trying so hard! I wasn't falling for it. Another local place said $OZ40 but I wasn't convinced on their dedication to a great job after the brake hubs they sandblasted weren't 100%.
I rang the place that did my last set years back. The fellow has since retired but I chatted to his successor and he said all the right things..like $OZ60 per wheel. I'll go see him next week.
Seals and bearings are out. The rear bearings were a tad rough...just. Front felt fine.
Posted: Fri Apr 27, 2018 7:46 pm
by Beemerboff
When I wanted my VRF wheels re coated I knew a little about heat treating aluminum from my time in Pop's welding shop, so I contacted the production managers of the two companies in Adelaide who at that time made alloy wheels, including for Harley Davidson.
I knew them both from my time in the construction / concrete industry , so I was given the courtesy of a detailed answer.
They both confirmed my suspicion that alloy wheels are subject to complex and lengthy heat treatment process which gave them their strength, and the temperatures involved in commercial powder coating would removes some of this strength, and should not be considered in any circumstances.
One even suggested that all powder coat companies in the state had been instructed not to do it, and it was actually illegal in this state.
Most critical components like wheels will be designed with a pretty decent factor of safety to cover for the occasional mishap, and the percentage strength loss will depend on the the composition of the alloy and the heat treatment it received initially, and of course the temperature of the powdercoat oven.
So while every wheel will be weaker and I am not saying that every wheel will be weakened to a dangerous degree, for normal road use in the hands of a mature and sensible rider
But there is only one way you are going to find out if it is!
Maybe on a bump on the next corner------------
Posted: Sat Apr 28, 2018 9:31 am
by PAS
I used Duplicolor silver metallic lacquer top coated with clear lacquer. Look OEM and are easily touched up.
Posted: Sat Apr 28, 2018 6:27 pm
PAS wrote: ↑Sat Apr 28, 2018 9:31 am
Does it come in gold?
Posted: Sun Apr 29, 2018 9:50 am
by Beemerboff
The reason I suggested the Hammerite red etch primer is that Hammerite make two primers, and the grey one is for steel.
The Hamerite red etch primer is one that has been proven to get a good bite into aluminum , and seems to be one that folks consistently have success with when recoating tricky things like factory coated engine cases.
I dont think Duplicolor make a aluminum etch primer, and their clear is soft and yellows if near heat or petrol. DAKIK
Duplicolor color coats are fine, their Honda Milano Red is a perfect match for my red Funduro , and has come up great without a clear over, just leveled with 2000 paper and then Armorall Cut and polish.
Posted: Mon Apr 30, 2018 1:55 am
by Zombie Master
I see.
Posted: Mon Apr 13, 2020 3:45 am
by dirtsurfer
Any pictures of the finished wheels Steve?
Posted: Mon Apr 13, 2020 7:56 am
by daz
DUPLICOLOR BGM0516 PERFECT MATCH AUTOMOTIVE PAINT, GM GOLD METALLIC, 8 OZ AEROSOL CAN
acrylic lacquer aerosol paint
Posted: Mon Apr 13, 2020 12:21 pm
Posted: Wed Apr 22, 2020 5:58 pm
by Zombie Master
A handsome machine.
