No Clutch
Re: No Clutch
You dodged a bullet there, Kelly. It's advisable to replace the 'pin' with a bolt and Nylok nut.
Pity about the persistent 'no clutch' situation. Better get that gearbox out for a look-see.
KellyVB 75R90S
Re: No Clutch
Post by KellyVB 75R90S »
Airbear,
Know where to get that nut and bolt from?
I did order the upgraded pin and keepers from MAX BMW yesterday but your solution sounds MUCH better.
Highest Regards
Kelly
Re: No Clutch
I went to the hardware store. What you want is a bolt with an unthreaded section long enough to span the ears and as close to 8mm as possible. I used two nuts locked together so the bolt could float a little and the cast in ears weren't pinched. To keep things from rattling around I used a couple wave washers.
KellyVB 75R90S
Re: No Clutch
Thanks, will do that
George Ryals
Re: No Clutch
Post by George Ryals »
You might want to put the pin in from the top so the pin won't fall out if the keeper goes missing again.
Re: No Clutch
George Ryals wrote: Tue Nov 06, 2018 2:21 pm You might want to put the pin in from the top so the pin won't fall out if the keeper goes missing again.
My own approach has been to use a long enough metric sized bolt instead of the pin. With a nylock nut holding the bolt(pin) in place, a person won't have to worry about the previous pin coming out and breaking the cast aluminum ears on the transmission back cover.
