Fork Rebuild Stiction Help
dswassy
Re: Fork Rebuild Stiction Help
Post by dswassy »
Just to follow up in case anyone is interested, still no luck with any of the suggestions. The only thing I can think of is that the forks are out of alignment, and for some reason that doesn't show when doing the stiction pull up and drop test without oil in the forks. I have taken them apart and fiddled maybe five times now without luck, so I think I have to give up and leave them as they are...sticky.
Have you been here:
https://w6rec.com/204-2/
This has been my method for Airhead forks. Works 2 out of the 2 times I've done it!
dswassy
Post by dswassy »
Bill Smith wrote: Thu Apr 25, 2024 11:03 am If it's truly stiction instead of thick fork oil, try this: During my rebuild, several sites recommended loosening the upper and lower triple clamps and the fender mount / brace and bouncing the bike by rocking it. This lines everything up and seemed to work well.
Do you mean after everything has been put back together? Hard to rock it without a front end.
dswassy
Post by dswassy »
melville wrote: Thu May 30, 2024 9:38 pm Have you been here:
Thanks for sending that along. I will give it a shot, though seems complicated and easy to mess up.
