what is the test for the charging circuit?
Does anyone have numbers related to RPM's that it should be putting out?
Do you just do a voltage check across the battery or a check across a load other than the battery?
dry battery - trash it or charge it
Re: dry battery - trash it or charge it
Buy land. They ain't making any more of the stuff.
Will Rogers
1977 R100/7 dressed up like a R100s
Will Rogers
If you're testing the charging system out you check at the battery poles. Can't remember the exact numbers, but you should be producing 14+ volts with the engine up 3 to 4K rpm. Someone will have the spec shortly.BoxerTwin wrote:what is the test for the charging circuit?
Yo can study here. Might have to scroll down and dig around. But it's all here:
http://bmwmotorcycletech.info/techindex.htm
You can find many sources. My site has a bit. http://w6rec.com/duane/bmw/battery/index.htm
