Can anyone ideentify this shock absorber /
Re: Can anyone ideentify this shock absorber /
In a reservoir, it's probably nitrogen. I think, if you remove the protective cap over the valve, the valve may tell you.
nope.. valve may look the same, it's nitrogen.
check this out
http://search.ascycles.com/motorcycle/Shocks
check this out
- Sibbo
I can't find it there !
The Grateful Dead
The Grateful Dead
That's because it's not. The shock he is linking to still doesn't have the reservoir yours has, but it may have changed over the years. If so, it's going to be much harder to figure out.Sibbo wrote:I can't find it there !
- Sibbo
OK ,I found a bit of text on a label on the underside of the reservoir ...I missed it last time I looked
It's in Italian and English . At least I think it's Italian ...
Does that help ?
Perhaps it's an Italian aftermarket bit ...!!!
Does that help ?
The Grateful Dead
The Grateful Dead
- Sibbo
We have a possible ID !
I emailed Shocktreatment and go the following response ....
Peter
I would not be so sure that the shock isn't standard. It would appear to be
either a Boge or a Marzocchi, both of which have been supplied as standard
on BMWs.
Marzocchi sounds right with the Italian text under the reservoir .Has anyone ever heard of Marzocchis on an R80
Peter
on BMWs.
The Grateful Dead
The Grateful Dead
