Page 2 of 3
Re: S men!
Posted: Fri Apr 22, 2011 2:32 pm
by Zombie Master
[quote="Ken in Oklahoma"]
Best optional windscreens: — A medium height parabellum so I don’t have to keep doing pullups against the wind.
Barn door fairings: — Depends on my mood. When I’m about ease and creature comfort I take my ‘77 R100/7 with its barn door Luftmeister fairing, and cases including the infamous top box. With the /7 I strike a pretty good old-fart-on-a-slow-Beemer stereotype. (On the S bike I strike a pretty good old-fart-on-a-better-bike-than-he-deserves stereotype.)
Now ZM, I have a question for you: Why do you ask?
Oh I forgot to put in my earplugs in coming home last night, and I could hear a bit of noise that I could damp out with my hand on the fairing. My headlight also seems to be tilting down due to the location of the rubber seal. It will be improved. Just thought I put it out there and see what up.
Re: S men!
Posted: Fri Apr 22, 2011 3:34 pm
by dougie
Zombie Master wrote: My headlight also seems to be tilting down due to the location of the rubber seal.
Have you tried using the eccentric locators on the turn signal mounts to centre the seal around the headlight?
Re: S men!
Posted: Fri Apr 22, 2011 5:52 pm
by Boertjie
I don't have a fairing on my 77S. But agree with the brakes issue, very poor front brake indeed..
Re: S men!
Posted: Fri Apr 22, 2011 10:16 pm
by Zombie Master
dougie wrote:Zombie Master wrote: My headlight also seems to be tilting down due to the location of the rubber seal.
I know what you are talking about, and yes I've messed around with them a bit. What keeps them in place?
Re: S men!
Posted: Sat Apr 23, 2011 7:28 am
by dougie
Zombie Master wrote:dougie wrote:Zombie Master wrote: My headlight also seems to be tilting down due to the location of the rubber seal.
The signal light on the outside and the metal cap with the slot on the inside.
The eccentric rubber grommet should should be snug on the signal bracket.
Re: S men!
Posted: Sat Apr 23, 2011 7:32 am
by DanielMc
dougie wrote:Zombie Master wrote:I know what you are talking about, and yes I've messed around with them a bit. What keeps them in place?
There seems to have been at least two slightly different systems used here - on one of my S bikes I've got a one piece eccentric grommet/bush and nothing else and it works just fine. The other bike has the two piece bush and the metal cap, which keeps trying to fall out...
Re: S men!
Posted: Sun Apr 24, 2011 4:10 am
by DanielMc
Well my Gaydar may not be very well developed but that guy!
The RS is no doubt presents with gentilesse, and elegance, but does not have the testosteronic mechanical presence of a good S.
Not so ZM. While we of the S persuasion rightfully value the full-blooded machismo of nearly unfaired motorcycle, there are some things that sophisticated ladies would rather not see. Here's another pic of the redoubtable Mr Olgilvy basking in the adoration of a couple of babes who broke through the security barrier - believe me this guy needed a large stick dipped in dogshit to even consider walking down the street without risking sexual assault.
Who knows - lose the hippy musician vibe, get a haircut and some tight fitting pants and put a decent fairing on your scooter and you might get noticed. Only problem I can see is that if it's a regional Gaydar thing you might not be attracting just the ladies, so don't forget that shitty stick...
Re: S men!
Posted: Mon Apr 25, 2011 3:09 am
by Zombie Master
Re: S men!
Posted: Mon Apr 25, 2011 3:54 am
by KenHawk
[quote="Boertjie"]I don't have a fairing on my 77S. But agree with the brakes issue, very poor front brake indeed..
Do what I did.
Ditch those ancient rubber hoses for braided SS lines, swap up to a 14mm handle bar master cylinder, rebuild the calipers using HH pads and I guarantee that those brakes will work very well!. Not like modern brakes but a whole lot better!
Re: S men!
Posted: Mon Apr 25, 2011 7:55 am
by Boertjie
KenHawk wrote:Boertjie wrote:I don't have a fairing on my 77S. But agree with the brakes issue, very poor front brake indeed..
Do what I did.
The conversion kit from motobins is a bit pricey, will wait for a donor/scrapped bike (and that could take forever). My question is: will upgrading to ss braided lines make the brake better? Personally I get no difference in braking from my r60/6 drum brake and the R100S disc brakes. If I take a ride with my friend's RS it feel like I'm in braking heaven
