Re: Swinging fork lube.
Posted: Mon Jun 06, 2011 7:04 pm
I just hate when that happens.Sunbeem wrote:
PS Big explosion in Cern today. Apparently, a waitress carrying a tray of pasta, collided with a plate of anti-pasta ...
I thought that's what they were trying to do. Good one, Sunbeem!Garnet wrote:I just hate when that happens.Sunbeem wrote:
No offense, but if someone has gone through that much grease without thinking there may be a problem, it's time to put down the bong.Tim Shepherd wrote:It's all good, until you realize the plate behind the bearing on the left side has rusted through, and you've pumped a tube of grease (or two) into it...wirewrkr wrote:no.lrz wrote:Swing-arm? It's more of a re-pack situation,no?
The swingarm pivot bolts are hollow for a reason.
You shove the grease gun (with the proper tip) to the end where you would normally put your 6mm allen wrench and
have at it until you start to see grease coming past the seal.
When you're done, wipe off the excess and bobs yer uncle.![]()
