Clutch plate screws, not bolts. Impact wrench?
George Ryals
Re: Clutch plate screws, not bolts. Impact wrench?
Post by George Ryals »
You can always weld a nut to each screw and use a long box end wrench or 6 point socket with a long ratchet handle.
Post by Deleted User 287 »
George Ryals wrote:You can always weld a nut to each screw and use a long box end wrench or 6 point socket with a long ratchet handle.
I think I would remove the engine from the frame and do it on the bench, first.
Here is a nice little impact screwdriver set from Mike's XS supply.
The one at Sears works just as well (same money) but this one has a box to keep everything together.
http://www.mikesxs.net/products-7.html
Almost to the bottom of the page.
And they do work well for the job at hand......... cept when you get that bit of skin between your thumb and forfinger over the end of the driver, and then hit it with the hammer. Then the driver goes flying across the shop and the bit falls out under the work bench where you are afraid to stick your hand. :oops:
jjwithers
Post by jjwithers »
Native /5 wrote: Josh,
I have found that with those impact drivers it helps to put a little twist into the driver with your holding hand, in the direction you want the screw to turn, while whacking with the hammer. You can feel a detent when you change directions with the driver. Turn it past the detent in "your" direction, then hold it against the stop while whacking.
I got a new Impact driver. (the one recommended on this topic from Mikesxs.com). I twisted the driver while whacking it and it took 3 screws out very easily. The other 3 put up a challenge... so out came the propane torch. The the 4th came out easy. The 5th took a bit more work... and well, the 6th...it gave me a nasty blood blister but i finally got it.
Thanks to all those that chimed in.
-Josh
tools for the job.
tools for the job.
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
mattcfish
Post by mattcfish »
Every project requires a little blood letting. Your work area sound remarkably similar to mine. Never can remember where I put all those rat traps.
jjwithers wrote:and well, the 6th...it gave me a nasty blood blister but i finally got it.-Josh
OUCH!
