It's really useful when you are warming her up .Cruising you don't lock it ,just reduce the return pressure a bit ....easier on your wrist .dougie wrote:I don't understand how locking the throttle on can be a good thing.
Just sounds dangerous to me.
Throttle lock thread ?
- Sibbo
Re: Throttle lock thread ?
The Grateful Dead
The Grateful Dead
Throttle lock is a misleading term. It isn't difficult at all to roll the throttle off.dougie wrote:I don't understand how locking the throttle on can be a good thing.
Throttle locks do make it easier to clean the bike while riding tho'.
Sibbo, my bolt is 8mm x .8mm I think. 13-14 threads over 10mm.
Overall length is 20mm with the last 5mm stepped down to about 4mm.
- Sibbo
Thank you sir ! I'll pick up a cap screw and turn the end down a bit and see how well it works .
The Grateful Dead
The Grateful Dead
OK, now I get itSibbo wrote:It's really useful when you are warming her up .Cruising you don't lock it ,just reduce the return pressure a bit ....easier on your wrist .
We didn't give the thread dimension because we don't know it. I think it is pretty special and probably not available in the hardware sources. If I wanted to plug the hole, I'd whittle a hardwood plug.
- Ken in Oklahoma
At one time Justin Bowser, who used to frequent this forum, was starting production of that throttle "cruise control" do dad. I believe Justin is still the custodian of the R65 list, so a bit of googling might get anybody interested in touch with him.
why, is his better than the one from BMW?
part # 32721230874 LOCKING BOLT $9.42
or, you can buy the plastic plug that BMW sells for that hole.
part #32721236605 PLUG $0.53
Wave at HD riders?Chuey wrote:You may want to reconsider after learning that I use mine all the time. It allows me to use my right hand. I wouldn't be able to wave to Harley riders if not for it. That's reason enough.
Ideal requirements for a home made job.Sibbo wrote:Thank you sir ! I'll pick up a cap screw and turn the end down a bit and see how well it works .
The throttle screw *must have a large diametre knurled head to enable easy operation with yer gloves on while riding.
And just the right spring tension range so one doesn't end up fighting spring pressure before the desired setting is achieved.
Just like a bought one really.
But! you do have a lathe?
*safety, simple to use. imo.
