Did you put your shim on the clamp side or behind the "small piece of sheet steel with a serrated edge"?vespajg wrote:I've used coke can shims in mine before and they never failed. Admittedly not elegant, but effective. I'd take the latter over the former any day...
I'm tempted to go with the clamp side, because I have a Cyber Lite stuck to the inside of the outside of the turnsignal box. That makes sliding the T.S. off the stem a bit more complicated.
