Voltage regulator question...
Re: Voltage regulator question...
14.8V is a bit high but will not damage your battery. It will go through more water so must be checked more often. Like the others I would pop in the old Bosch iffin I was going a long trip with multiple 10 or 12 hour days, just to cut down on water consumption.
If your like me and do most of your long distance ridding in your mind, don't worry be happy.
The above is based on an old fashioned lead acid battery. If you are modern and sealed, then you have less to worry about, just check it for temp after an your or two in the saddle.
Garnet wrote:The above is based on an old fashioned lead acid battery. If you are modern and sealed, then you have less to worry about, just check it for temp after an your or two in the saddle.
Actually, I believe Gel's are more susceptible to damage from over/too-fast charging
MS, yes the gel batteries that we use are even temperature compensated and that is in a room that is carefully kept within a few degrees. The charge voltage is controlled to within a few hundredths of a volt.
Yes a "Ge"l deep cycles is very sensitive to too high a voltage, but most (edit) sealed motorcycle batteries are AGM (aborsbed glass mat) which can take a bit more voltage than a lead acid and a lot more than a real gel.
Just wanted to clarify that "modern and sealed" isn't enough. There's sealed gel, sealed lead acid, and sealed AGM.
Major Softie wrote:Just wanted to clarify that "modern and sealed" isn't enough. There's sealed gel, sealed lead acid, and sealed AGM.
I just discovered a few days ago that there is such a thing as an unsealed AGM--well sort of. I was shopping for an AGM battery and the nice young man at O'Reilly's brought it right out. That was easy, I thought. Then I opened the lid and saw what looked like a string of six little acid bottles full of acid.
"No, I'm looking for an AGM battery," I corrected.
He then explained that it is an AGM battery. You put the acid in the battery and then there's a cap that you seal over the openings.
"That's one of the prime reasons I want an AGM", I said, "so I don't have to fool around with acid". (I was thinking of the many holes I've put into jeans over the years and the number of times that clear hose popped off that tapered little nipple on the acid container, splattering acid over the top of the battery and/or the bench--and occasionally my jeans.
"No problem," he said. "We can put the acid in for you. (He sure was being helpful, that nice young man.)
"No," I said, my stubborn inner curmugeon taking over the conversation. "I'm going to pass." (I know that doesn't sound very cranky. You needed to be there to see the cranky look on my face.)
And then, miffed, I escaped and found the AGM battery of my dreams at Auto Zone.
And I'm now living happily ever after (so far).
Ken, happy in Oklahoma
teo
Post by teo »
Ken,
Not to judge, but the "6-bottle applicator" is ingenious and virtually spill proof. The batteries are "sealed" after you put the acid in them. The lids click shut tightly and can only be opened with the same force and ingenuity you would have to use on a "factory sealed" battery.
I had first hand exposure and practice with this system last month when my 1.5-yr old factory-sealed (*(#^$*&^@*&^&*^) Westco croaked in the middle of a baking Kansas. I bought a suitable battery at Walmart to get back on the road. WalMart's EverStart AGM batteries come empty of acid and must be filled. I got to thinking that it is not all that bad as the battery is new, gets its first charge when you fill it, and is literally factory fresh at that moment. It's working fine and there are no spills or leaks or messinesses.
Teo
teo wrote:Ken,
Teo
Yeah, that would be a bit of a pain, but it does mean that you know the battery hasn't been sitting there deteriorating on the shelf for months.
2valve
Post by 2valve »
[quote="Garnet"]
thats a good one :lol: , me to!, actually dont ride the bike hardly at all :( " no " shellbe you cant have the bike :D , thought i'd get in first this time .
She'llbe
Post by She'llbe »
Damn!!!!!!!!!!!!!!!!!!!!!!!!
From the desk of the
Mt. Nardi Yacht Club
PO BOX 95
Nimbin, NSW
Australia 2480
02-6689-1234
