Page 2 of 3
Re: Dimensions of conrods
Posted: Thu Sep 22, 2011 9:10 pm
by vanzen
R85/8 wrote: There's a wide range of competition rods for the 2002 - inc titanium - so this could get more interesting....
350g Titanium rods to fit are available from HPN:
Also Carillo will make connecting rods to specification.
Posted: Thu Sep 22, 2011 10:42 pm
Very Very pretty.
Very Very expensive. 1100.00 € EACH
drool
Posted: Thu Sep 22, 2011 11:46 pm
by melville
But back on the VW idea--many aftermarket "VW" rods are made for smaller journals, 50mm or 50.8mm (2"). Perhaps a crank could be ground to match? Different lengths are available, possibly to use with pistons with a shorter compression height?
In the back of my head, and I don't know if any of this is feasible, I'm picturing a stroked R90, built with 90.5 VW 'stroker' (low compression height) semiforged flattop pistons, and R60 or other small chamber, small port heads, cut to give significant squish area. Just bringing some VW ideas into the Airhead. How much case clearance is there at BDC in an AIrhead?
Posted: Fri Sep 23, 2011 3:53 am
by R85/8
Now busy searching VW sites....
I wonder how much reciprocating weight could be saved in total with a conrod/piston combination.
Those HPN rods look like the ultra expensive way to do it, so I think I'll give them a miss. Besides, they're not shiny enough for the money :)
Posted: Sat Sep 24, 2011 3:59 am
by chasbmw
Melville,
Sounds like you want the Seibenrock 1070 kit.....
Posted: Sat Sep 24, 2011 11:53 am
by R85/8
chasbmw wrote:Melville,
May be showing my ignorance, but is that VW sourced parts?
Posted: Sat Sep 24, 2011 12:49 pm
by melville
No that's $$$$ourced parts. I saw a complete disassembled R90 motor at a swap last year, affordable, and I've been building it in my head since, assuming the barrels needed a bore and the crank a grind, and applying a bit of "why not" from my VW experience.
Building it in my head, as I didn't have the $250 that would have brought that one home.
The downside of VW stuff is that a VW that turns 7K rpm is a rare thing, but that's what stock Airheads do. Always a question about how long, and how often, you'd be able to wind the thing out.
Posted: Tue Oct 04, 2011 5:59 pm
by mattcfish
New from MI. Not cheap, but a better price than others out there.
These work with all cranks modified or not.
http://www.motoren-israel.com/product_i ... -Satz.html
Posted: Tue Oct 04, 2011 7:18 pm
mattcfish wrote:New from MI. Not cheap, but a better price than others out there.
480 grams? They're boat anchors! :lol:
Posted: Tue Oct 04, 2011 7:26 pm
by mattcfish
I bet that weight includes the bolts...maybe even the bushings.
