I'm trying to make some sense out of some spare parts I have on the shelf...hools100RS wrote:I recently bought some standard size, good condition, 90S pistons off AUS Ebay and presumed that they were the same size, weight, etc. Wrong!!! The pistons are a 89.970mm (3.5421") 'B' bore code and a 89.980mm (3.5425") 'C" bore code
Are your pistons actually stamped 89.970mm and 89.980mm? That what is stamped into the crown of the piston? Reason I ask...I have a set of R90S pistons that are stamped 89.975. The cylinders are stamped "B" and everything from the bike is original and low mileage. I've seen both 89.970mm and 89.975mm given as the spec. for "B" size.
