Rear Main Seal
Re: Rear Main Seal
A redhead in cowboy boots - the stuff of dreams!
- Jeff in W.C.
Re: Rear Main Seal Tool
If you don't have the time, or tools to make the tool, you can purchase one from Cycleworks. On the cheap side, I've read of some people using a 4" (I think it was a 4") piece of plastic drain pipe to assist in tapping the RMS in. Just take the seal to the hardware store and figure out which one fits the best.
http://www.cycleworks.net/index.php?mai ... f4a069ed68
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
1988 R100 RT
2018 R1200 GS
- Airbear
Re: Rear Main Seal
Yep, sorry. I couldn't remember whether it was a gasket or an o-ring for the oil pump, so I just called it a seal.bbelk wrote: You mention three seals. Is that the RMS, the transmission input shaft and (guessing here) the oil pump gasket?
I approve of your alternative method for getting the RMS into place. It is crazy to do the simple thing when it is possible to have such fun devising a complex system involving all available technology. Well done.
I also highly approve of your 'able assistant'.
Re: Rear Main Seal
she helped me on the Honda last spring, say hi! to the little sweetheart for me.
Re: Rear Main Seal
Brad - you might want to replace the o-ring on the front side of the flywheel, if your bike has one.
I don't know what it is, but it is cheap.
It is nearly the same size as the oil pump cover, so don't fret if one doesn't fit the other.
The oil pump cover o-ring is the smaller of the two diameters.
Re: Rear Main Seal
I hope I didn't throw you off w/ mention of the "special tool", I generally use a small hammer and a piece of wood(dowel,etc) for these seals...although I do have Jeff Trapps version. I've not blocked an Omega equipped motor, but as long as the crank remains stationary during dis/re-assembly that is all that matters.
Re: Rear Main Seal
bblek, she is way to cute for the likes of us guys.
Re: Rear Main Seal
And here is Richard showing off for Vanna White.....richard t wrote:she helped me on the Honda last spring, say hi! to the little sweetheart for me.
1979 R65
1979 R65
Re: Rear Main Seal
I agree, she is way too cute for you guys...Duane Ausherman wrote:bblek, she is way to cute for the likes of us guys.
Re: Rear Main Seal
No o-ring here:justoneoftheguys wrote:Brad - you might want to replace the o-ring on the front side of the flywheel, if your bike has one.
1979 R65
1979 R65
