Helpful Hints
Re: Helpful Hints
Sorry, I forgot.
Re: Helpful Hints
Yeah! He could be a politician!Duane Ausherman wrote:From MS, "Why, yes there should. BUT, I would never be so petty as to point that out myself.... "
Notice how cleverly he turned it around so deftly? Shheeesh.
Re: Helpful Hints
That's OK, it's good to see some post secondary education on the net.dougie wrote:Sorry, I forgot.
If I find any I'll post a link.
Re: Helpful Hints
Re: Helpful Hints
My helpful hint would be this:
If you have removed both wheels to have new tyres fitted then make sure you lash the centrestand so that it cannot move. If you don't ensure the centrestand cannot move you might find that, if fitting the rear wheel first, you inadvertently tip the motorcycle far enough forward for the stand to retract. If this occurs you will hear a loud bang, and will notice your motorcycle is now much lower because it's sat on its sump. To add insult to injury the drain plug sits a little proud of the sump base and will be knocked into the alloy causing a crack through which the entire contents of the sump will pass, forming a slick puddle of 20/50 around the bike. At this point the OP's advice might become very useful indeed.
Re: Helpful Hints
Are you using 140 wt gear oil in a BMW? Why? Does the spec call for that or is that what the dealer sold you?
Re: Helpful Hints
I think that this is a very good hint. While it is nearly impossible that anyone would do that, the chances are non-zero. Or, did you read about this somewhere? Give us a link. I want to read it as I can't imagine that anyone would be so up front and honest as to admit it in public. That person should be on the Oprah BMW show.DanielMc wrote:My helpful hint would be this:
Re: Helpful Hints
I heard about this somewhere, from a guy whose name I don't remember, who said it happened to a friend of his sister's husband's neighbour I think.Duane Ausherman wrote: I think that this is a very good hint. While it is nearly impossible that anyone would do that, the chances are non-zero. Or, did you read about this somewhere? Give us a link. I want to read it as I can't imagine that anyone would be so up front and honest as to admit it in public. That person should be on the Oprah BMW show.
The new sump on my R90S was fitted for purely cosmetic reasons and I defy you to prove otherwise...
Re: Helpful Hints
When you lower the tailgate on a pickup truck, the truck gets LONGER! (ask me how I know). One day I plan to hire a team of Scientists to explain this Doppler-like effect.
Vince
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
1952 Triumph TRW
1936 BMW R2
Re: Helpful Hints
It slows the leaks and quites the shifts in that POS airhead transmission. The Japs would not build a bike with a 70K bomb in it. The only downside seems to be on sub 40 degree days, which don't happen often here. When it does, I have to drive a block in first gear before it will shift well. After that, it does everything better.CVA-42 wrote:Are you using 140 wt gear oil in a BMW? Why? Does the spec call for that or is that what the dealer sold you?
1979 R65
1979 R65
