Electronic ignition advance.
Re: Electronic ignition advance.
dougie wrote: Thought about that once. Figured I could dig a hole in the sole of my boot to fit over that little gearbox lever. :idea:
Just wear 20+ yo boots like me.........no need to dig anything!
My 15 year old Blundstones should work. :mrgreen:
dougie wrote:My 15 year old Blundstones should work. :mrgreen:
Commonwealth shoe exchange?
Well I'm glad you've moved on from ignition to footwear in less than one page.
And I did nothing to help. :oops: (as usual)
Ignition?
Ig...nit........ion................ IGNITION!
Right! Well yes, there's no point advancing this thread until I've checked my timing.
It did seem pointless.
Ok. S /OT is in the middle of the window at 1100 rpm. All is well....or well enough.
3000 rpm has Z at the bottom of the window and rises slightly higher at higher rpm.
Not the cause of the higher rpm breakdown.
Regarding float level, I can be riding at say 3500 in third, give it WOT and have the engine stumbling as soon as it gets to 6500>
I reckon I can hit the higher revs before the fuel level drops enough to cause a problem.
Or, I can go from throttle fully off at said rpm, give it WOT and get same response.
George Ryals
Post by George Ryals »
Bump your main jets up(or down) one size and give it a try.
It's a recent problem George. The engine has often been 7500+ and even just over 8000 some months ago.
I have noticed over the last few months the engine being a little reluctant to reach these high rpm with the usual ease.
I have at times found that too tight on the valves will cause the same thing but the valve settings are good........
With a little more memory applied, the breakdown seems to be an inconsistent one, as in I can feel spurts of enthusiasm from the engine during the breakdown.
With even a little more memory applied, I can detect faint reminders of a similar issue I posted about. Hmmm.
I should have a replacement gear linkage arriving this week so I can check things out.
George Ryals
Plug wire insulation breaking down under high load?
