When the crankshaft is at OT (OT showing in lower half of timing hole), the keyway is at 9 o'clock. There is definitely no mark on the crankshaft sprocket, but with the flywheel correctly installed it doesn't need one.
The camshaft sprocket actually has a mark (it is faint so I didn't see it before) which lines up with keyway which is now at 12 o'clock.
Seems this is how it's supposed to come together.
