Page 2 of 7
Re: Elementary question - leaky carbs
Posted: Sat Oct 27, 2012 2:35 pm
by Chuey
Oh, I forgot to mention, it ran really nicely when I started it up. The only thing is it was leaking gas from the carbs.
Posted: Sat Oct 27, 2012 3:42 pm
by Darryl Flynn
Sticky float needle. 100%
Darryl
Posted: Sat Oct 27, 2012 4:38 pm
I've had a nice idle with fuel pissing out of one or both carbs.
How old did you say your needles were Chuey? As has been said, start with new needles to make an assessment.
It is indeed unlikely that the seats are the problem, unless someone like me has been in there.
My float pins are now removable either way, as they have been out that many times.
It doesn't really matter if the pins are loose because they can't come out when the bowl is in place. The bowl is about 2-3mm from each end of the pin. The best thing about a unidirectional pin is that there is no....er, what way does this thing go again...
The hair springs that hold the needle to the tang (if you have them) are a pita. The carbs will function perfectly without them.
Flamin' Boots.
Posted: Sat Oct 27, 2012 8:23 pm
by lrz
Been roofing all day; here's that link:
http://www.bmwmoa.org/forum/showthread.php?t=60489
Pretty lo-tech.
Re: That link was a trip!
Posted: Sun Oct 28, 2012 12:03 am
by Chuey
I liked it when one of the comments said he was a "little leary". I guess you never know when someone will drop acid and decide to rebuild BMW carbs. Wow! It's like a whole universe in that float bowl! Those floats are so beautiful! Wow, man.
I'm pretty sure it's just some stuck needles. I'll dig into it tomorrow morning.
Posted: Sun Oct 28, 2012 2:03 am
by Garnet
Chuey wrote:I liked it when one of the comments said he was a "little leary". I guess you never know when someone will drop acid and decide to rebuild BMW carbs. Wow! It's like a whole universe in that float bowl! Those floats are so beautiful! Wow, man.
After the effects of the wine, I hope.
Posted: Sun Oct 28, 2012 2:08 am
by Garnet
ME 109 wrote:I've had a nice idle with fuel pissing out of one or both carbs.
Flamin' Boots.
I just dug my winter /5 out of mothballs and am not allowed to leave my boots (left one) in the front hall closet.
Maybe I'll fix it tomorrow with Chuey. But it's supposed to be sunny.................
Posted: Sun Oct 28, 2012 6:30 am
Chuey wrote:I'm pretty sure it's just some stuck needles. I'll dig into it tomorrow morning.
'Course there's always the possibility that some crud from the tank or a bit of fuel line has got itself stuck in the seat where the needle contacts. I've had that before.
Sometimes allowing the float to drop all the way down and turning on the fuel will flush it out.
Otherwise disconnect the fuel line where it enters the carb and give it a shot of compressed air where the needle goes.
Posted: Sun Oct 28, 2012 3:44 pm
by George Ryals
The float level could be too high and the leak is the overflow. or the float could be sinking, causing a high level in the bowl to be too high.
Posted: Sun Oct 28, 2012 7:59 pm
by khittner1
Chuey----It may be the float needles/seats as others have suggested, but there may be a more elementary cause for the leakage---are you sure that your leaking problem isn't from shot or misaligned float bowl gaskets? I've found that whenever I pull my float bowls off, there's about a 1 in 4 or 5 chance that I don't get the bowls and gaskets just right, with fuel leaking onto my toes (or a puddle under the affected side) being the first indicator. Fresh float bowl gaskets, fully tucked into their retaining grooves on bottom of the carb bodies, might be a problem-solver if you're lucky.
Konrad
