Page 2 of 2
Re: front drum brake
Posted: Fri Mar 01, 2013 7:32 pm
by robert
jjwithers wrote:Major Softie wrote:Then, of course, there is the most cafe solution of all: fabricate one from scratch.
Replicating those spline teeth would be REAL tricky...
[img]http://i1274.photobucket.com/album ... .jpg[/img]
I made a spline forming tool from an old /5 brake part. The dims. are the lead and the final size. The hole should be about .430 or so. Push the tool through with lube, clean and relube and push it back through. 6061 t6 is a good alloy for forming. Disclaimer--This worked for me, do not try this at home.
edit:R clik on foto, view image for full foto.
Posted: Fri Mar 01, 2013 8:16 pm
by Deleted User 62
Robert, you da MAN!! Extra points for using a part of the bike to make a tool...
Posted: Fri Mar 01, 2013 8:20 pm
by jjwithers
Start making a batch of longer brake arms please?? I would be first in line to buy a set!
Posted: Fri Mar 01, 2013 8:28 pm
Don't do it, Robert. Making your own brake parts is totally cool. Making them for others is a horrible liability lawsuit just waiting to happen.
Posted: Fri Mar 01, 2013 8:40 pm
by robert
Major Softie wrote:Don't do it, Robert. Making your own brake parts is totally cool. Making them for others is a horrible liability lawsuit just waiting to happen.
Thank you MS. I wasn't planning to. Just a bit of info for those that want to make them.-----Sorry JJ--RG
Posted: Sat Mar 02, 2013 9:37 am
by jjwithers
Party Poopers.
Posted: Sat Mar 02, 2013 2:30 pm
He could loan you his splining tool though.
Posted: Sun Mar 03, 2013 12:22 pm
by Chuey
Major Softie wrote:He could loan you his splining tool though.
I think the point is that there is one (the tool)on your bike.
Posted: Sun Mar 03, 2013 1:49 pm
by Ken in Oklahoma
Chuey wrote:Major Softie wrote:He could loan you his splining tool though.
With a big enough hammer it would surely do the job!
(I guess a person could "cheat" and heat up the to-be-splined brake arm to red hot first.)
Posted: Fri Mar 08, 2013 11:43 am
by Motorhead
SORRY NO PHOTO YET
I used 1 set.. my welder buddy made a set 1" longer
I bolted 1 side to a table an hung 40lb 1 part broke as the waight was on it the other is holding this minute
in thin plane this weight test should produce a sound part if it holds, as it works in the thick plane in operation
I see this project has turned some certain interesting ideas in mfg an libility
as its your bike an your work the falit can only be the one rideing it
I never seen a group so intent on fring the cook as beemer heads
