Doesn't make sense to me either...chasbmw wrote:That's not very logical?Zombie Master wrote:Rear flats are more common. When I'm only packing one tube I take a front, it will work in the rear as a temporary fix.
Tubes
Re: Tubes
Re: Tubes
Right, I'm in the pub at Hillston NSW having lunch with the other lads.
Heading north to Nymagee for the night.
I wasn't sure who to believe so I believed yez all.
I took a front tube, a back tube, and no tube.
Re: Tubes
I know you were trying to save space, so where did you put the no tube?ME 109 wrote:Right, I'm in the pub at Hillston NSW having lunch with the other lads.
Re: Tubes
I too would rather have a spare front for use in the back as opposed to a rear stuffed into the front. Makes sense to me.
Re: Tubes
I guess I should have written: Though rear flats are more common, when I can only pack one tube I'll carry a front tube as you can use them in both wheels. The smaller rear tube shouldn't be used in the front IMO.chasbmw wrote:That's not very logical?Zombie Master wrote:Rear flats are more common. When I'm only packing one tube I take a front, it will work in the rear as a temporary fix.
Re: Tubes
I'm in the opposite camp. I'd much rather have a tube have to stretch out to fit than have folds inside the tire.Zombie Master wrote:I guess I should have written: Though rear flats are more common, when I can only pack one tube I'll carry a front tube as you can use them in both wheels. The smaller rear tube shouldn't be used in the front IMO.chasbmw wrote:That's not very logical?Zombie Master wrote:Rear flats are more common. When I'm only packing one tube I take a front, it will work in the rear as a temporary fix.
- dirtsurfer
Re: Tubes
I once stuffed an inflatable dinghy into my 18" rear tyre it got me home no problem. Now I always carry oneME 109 wrote:Right, I'm in the pub at Hillston NSW having lunch with the other lads.
Re: Tubes
Good one Max!dirtsurfer wrote:I once stuffed an inflatable dinghy into my 18" rear tyre it got me home no problem. Now I always carry oneME 109 wrote:Right, I'm in the pub at Hillston NSW having lunch with the other lads.
Now we're at Nymagee pub knockin' back a few beers.
1 Klm out to the ol' horse racing track and set up camp and get those steaks cookin'
There's reception here out in the middle if shit creek so expect some nonsense.
Re: Tubes
And the inside diameter is.....Tim Shepherd wrote:Using a front tube in a rear tire won't make it bunch up. The outer diameter is the same.
