80mph speedometers.
Re: 80mph speedometers.
It's a 2.91, and mine is a 33:11 final drive. I knew that when I bought it. It'll still be close, and my current odo is way out. I also get another odo, a tacho and the case.
Gidday fellas,
I'm to busy just hang'in on to be worried bout my speedo.....
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Haha...I doubt you'd notice your tacho was kaput either
dougie wrote:I believe they were on models during the gas crunch when the U.S. highway speed limit was 55 mph.
Don't know if it will break when you go faster than 80.
Gov'ment regs mandated the 80 mph clock in the U.S.
NO, they will not break if you go faster ... guaranteed.
My '81 3:1 RS with a factory clock was optimistically inaccurate by 5 mph at 60 mph.
Top speed at 118 – radar confirmed.
oops..double post..
If I'm using a 33:11 with the (140mph) 1.112 speedo ratio, verses a 33:11 with the (85mph) 1.078 speedo ratio, with the known inaccuracies as described by MS, which might be most accurate if compared to a gps? Anyone know mathematically?Jean wrote:Oh well, so much for "ACCURACY".
Rear tyre diameter is 79.75 inches (203 cm) average of 3 full rotations seated on the bike. I guess higher speeds will cause some centrifugal expansion and lengthening of number???
Look at how they are made. The only connection is magnetism via the cup limitor. No damage can occur from over speed, at least not to the speedometer.
Re: Accuracy is such a laugh
Steve, since we ALL have different tires than the original, and the profile has changed quite a bit in the last 20 or so years...speedo "ACCURACY" is probably only a figment of anyone's imiganation. (I ran a 120 x 18 instead of a 4.00 x18 for a while, go figure!)
NOW, with the electronic speedos than can be adjusted, that's another story.
