Page 2 of 3
Re: Battery for R75/5
Posted: Thu Sep 03, 2015 1:47 pm
by barryh
One problem with Gel and AGM batteries is the bikes charging system wasn't designed for them and the AGM in particular needs a significantly higher charging voltage than a standard wet cell. The best thing you can do is get an adjustable voltage regulator and set it at the voltage the battery manufacturer recommends. Don't listen to generic advice about what voltage to charge a GEL battery at for example. Just trust the battery manufacturer. Once the correct charging voltage is used both GEL and AGM batteries are very superior compared to a wet cell in that they have a vastly lower self discharge rate which will help if the bike is infrequently used or used for short journeys.
Posted: Thu Sep 03, 2015 5:40 pm
by slyngej
Would it be a good idea to replade the diode board and regulator with a newer rectifier regulator circuit?
Posted: Thu Sep 03, 2015 5:53 pm
by Foxy
I find Motobatt better than anything else I have used. Use them for my SWB R75/5 as well as my difficult to crank Ducatis. They hold their charge for months.
Posted: Thu Sep 03, 2015 11:03 pm
Foxy wrote:I find Motobatt better than anything else I have used. Use them for my SWB R75/5 as well as my difficult to crank Ducatis. They hold their charge for months.
Didn't Motobatt win somebody's big comparison test?
Posted: Fri Sep 04, 2015 4:19 pm
by Ken in Oklahoma
slyngej wrote:Would it be a good idea to replade the diode board and regulator with a newer rectifier regulator circuit?
I wouldn't spend the money, and it is a significant amount of money. The diode board and most airhead voltage regulators are solid state. So they don't wear out on a chronological basis. And they don't degrade significantly with normal use. Heat is the greatest enemy. Corroded connections can also be a factor
Now having said that I keep a known good diode board, regulator, alternator rotor and alternator brushes in stock because I know that sooner or later I'm going to need them.
Posted: Sat Sep 05, 2015 7:54 am
I've had a motobatt for about five years, and couldn't kill it when I left heated grips on for two weeks before noticing.
Cranks well in low temps.
The only trouble is, they're YELLOW
Posted: Sat Sep 05, 2015 9:00 am
by khittner1
The Motobatt's trademarked yellow case might be OK on a green or curry toaster tank. But I'm probably too fussy---I peel the red-orange-pink sticker off the front of my Westco AGMs before installing them.
Posted: Sat Sep 05, 2015 2:27 pm
Contact paper.
Posted: Sat Sep 05, 2015 6:40 pm
Major Softie wrote:Contact paper.
Good idea Major. I was lazy and painted mine matt black
Posted: Sun Sep 06, 2015 1:23 am
I thought contact paper was the lazy solution. ;)
